Advanced Interference Analysis plug in tool in creo
  • May 31, 2016
  • 1438 views
Hi everyone,
I know there have been many threads already discussed about global interference analysis feature in creo. But I wonder why PTC didn't give much focus on this functionality so far and to me it looks like a dumb feature in creo 2.
Anyways, have any one of you attempted to develop an intelligent plug-in in creo which can do better interference analysis and provide the true interference in an asm?
What kind of Intelligence which I tried to achieve is,
1) It should exclude threaded surface interference in std components (like bolts, nuts)
2) Small Interference between hoses, cables can be excluded.
3) Interference of about 1~2 mm in welded fabricated parts are not an issue, will be burned away in reality
These are just samples. We can make our own design rules based on our need.
I just am wondering how big companies are managing in this field. Which is the world best in class solution available now? Is there any apps or plug-in already available in market?
Please share your thoughts and ideas and suggestions. We are very much in need of a solution because we burnt our hands already in many projects.
Siva.
Hi
There will be another software called Vis Mockup from Siemens for this study,
In this we can define the rule as we want, i.e we can mention the interference values, so that it will provide the list of parts which are interfering (having more value than we specified)
Thanks.
