Animation License Issue
  • February 26, 2019
  • 5 replies
  • 2857 views
Our office recently upgraded our License to the PROE_DesignAdvP license which should include Animation.  However, when we click the Animation Icon we receive the following error message.
Application ANIMATION is not available or supported on this platform.
Any ideas on why this is?
please tell us:
  • what operating system is installed on your PC
  • what Creo version is installed on your PC
Notes:
  • some Creo functionality is not available if you use default installation procedure
  • you can also forward this question to PTC Support
JimC1-VisitorAuthor
64-Bit Operating System, x64-based processor
Creo-4.0-M030
I'll look into if we used the default installation procedure.
Jim
I checked installation procedure - I think Animate is installed by default.
Please double check your licence file (I guess it must contains module 137).
Sometime the license is split into several INCREMENT blocks. If module 137 is not present in PROE_DesignAdvP then it must have its own INCREMENT block. In such case parametric.psf file must contain following line:
ENV=CREOPMA_FEATURE_NAME=PROE_DesignAdvP (137)
