Any option to take input from Model intent program and use it in variant module
  • June 18, 2018
  • 0 replies
  • 1349 views
Hello All,
I would like to know if there is a way to take input (parameter) from Model intent program and use it in variant module to choose the options available in the module. This helps me to reduce one step in manually choosing the variant options from the module.
Eg: I have three plates (thickness 20,30 & 40mm) and corresponding attachments (opening 20,30 & 40mm). The thickness of the plate is assigned used the model intent program where in I get the input from user if they required 20 or 30 or 40mm. When the user selects 30 mm thickness, I want to variant module to select 30mm attachment and 40 for 40mm and so on.
Thanks for the Help!
Dinesh
