anybody using PTC Creo 5.0?
  • March 21, 2018
  • 20 replies
  • 8543 views
There haven't been 5 or 6 builds released yet to even test it!
It was only put out on the web for download on Monday.
Note the new naming scheme for Creo versions/builds.
This is release: 5.0.0.0.
Next release should be 5.0.1.0.
Chris3
Do you see it in the download center? It doesn't show up for me.
kdirth
Here where you can get a trial or upgrade.
https://www.ptc.com/en/products/cad/creo/whats-new
I think PTC will be following a similar pattern to Solidworks in releasing maintenance versions.there will be only upto CREO 4.0 M060.which means only 5 maintenance releases for CREO 4.0. Maximum bugs won't be resolved.
Then a new version will come up adding the old unsolved bugs and then the bugs from the new version.
This same process has made solidworks current versions horrible.
there will be two tracks if i remember correctly, long term support and the "usual" one (where the product becomes unsupported with the release of the next version).
i think that creo 4.0 is supposed to be the long term track.
i don't have access to ptc support so i can't confirm it
