Anyone from PTC... help?
Why in the world, when "improving" the drawing mode for WF5, did PTC take away the ability to "insert" a sheet in the middle of a drawing set and automatically move all the other sheets forward as needed. In the new release, (and this is verbatim from the Help Center): The new sheet is always added at the end of existing sheets within the current drawing, and the new sheet becomes the active sheet. Moving the sheet later will put it in the location you specify, but does not rename and automatically shift the other sheets... you have to do that yourself. In a drawing with over 30 sheets, where I want to add a sheet at page 3.... this means a lot of sheet renaming. Extra, un-needed work.
