Applying Pre-load to pressure enclosure end caps
I am trying to apply preloads to parts that make up a pressure enclosure assembly. We screw the endcaps to the main enclosure and then apply 120Nm as the preload torque. I have tried to simulate this by applying Force/moment Load with a component moment of 120Nm around the Z axis which is parallel with the length of enclosure. Is there anyway of transfering the 120Nm along the axis at the same time, this would then apply the correct loads to the component mating faces?
regards
Geoff
