Area calcul in familly tables
  • July 25, 2014
  • 6 replies
  • 2161 views
I need help to have the area of all instances in familly tables.
What is your method?
I have a parameter called SURFACE
And a relation : SURFACE=MP_SURF_AREA
but in the familly table, after adding the parameter SURFACE, and verifying all instances,
the aera is the same of the generic part.
My instance have different dimensions so I need each area for each instances.
Anyone have a solution?
Laurent
Best answer by mbonka
2-Explorer
July 25, 2014
put your relation for AREA calculating in POST REGENERATION relations. (see attached picture). In my opinion it means that ProE will do following:
- regenerate model (change of size)
- calculate relations
mbonka2-ExplorerAnswer
2-Explorer
July 25, 2014
lzanettin1-VisitorAuthor
Thank you,
it works fine,
In my family table, is it possible to put a "-" instead of the area for some instance?
we need the area only for gold plated instance.
Laurent
