Assembly arrangements
  • December 15, 2018
  • 2 replies
  • 2317 views
I'm trying to insert a sub assembly of a valve In an assembly. That valve has 2 instances. In the First instance the valve is closed, in the Second is open. Do I need to have 2 different assembly files, with the correct positions, or can I have just once?
Here an example of other software, of what I'm trying to do.
https://youtu.be/FOq0f7MEvj4
You should have just one model for the valve assembly.  This valve model should allow you to position the sub-components to achieve the open / closed state.  These states can be captured using the drag bodies / snapshot tool.  The saved snapshots can be re-used in snapshots of higher level assemblies, and for visualization in the valve's drawing (if made accessible as exploded states)
StephenW
When you use the word "instance", everyone is going to assume you are already using a family table.
You have options:
1. Use a family table "instance" and add the dimension that controls the valve open/closed.
2. Use flexible component to control the dimension in the assembly.
3. Or as pausob described using states.
