ASSEMBLY CUT USING COPY GEOM WITH TABLE SHELF AS AN ASSEMBLY
  • May 7, 2018
  • 0 replies
  • 868 views
I am trying to cut the leg area out of the shelf.
the leg is copy geometry that i have copied into the shelf asssembly.
is there a way to do an assembly cut using the intersection of the leg (copy geometry)with the shelf assembly??
i am using creo 4.0
