Assembly extraction path
  • May 16, 2019
  • 1045 views
I want to find the best path to assemble or dis-assemble a part into an Assembly, for occasions where you know the part will physically fit you just don't know what sequence of rotation/translations are required. Is there anything in Creo to do this, I know its possible in NX and CATIA so I assume it should be possible in Creo. Any help much appreciated.
I doubt that this is possible.
