Assembly mass properties
I have a purchased motor assembly that I know the weight (measured) and volume of (thru proe). I created a dummy material with the density equal to the weight / volume. After I assign the material to this assembly I don't get the correct value in the mass property analysis.
My ultimate goal is to get the weight of the upper level assembly that this part is used in.
Can someone set me straight?
Thanks - Mike
Thanks - Mike
