3-Newcomer
Assembly of subassemblies relations
im trying to make a relation in an assembly between 2 sub assemblies. tried to do as written in the website, but cant see the session id after enabling it.
i had a master part, that i created parts from it, then assembled those in 2 sub assemblies.
it calls the parts 'extern copy of id'.
your description is not sufficient. Please create test assembly and upload it as an attachment of your next reply.
TuxedoCat3-NewcomerAuthor
3-Newcomer
in this example i have a subassembly (asm1) made of 2 parts created from a master part (p1_prt1 and p1_prt2 created from p1), and another part p2. i created an assembly asm2 made from asm1 and p2.
asm1 have a cylinder and p2 a hole. how can i make a relation between the two radiuses in the asm2?
you files were created with an educational version of Creo Parametric. Therefore I cannot open them in commercial version.
Option 1: Start new discussion in https://community.ptc.com/t5/PTC-Education-Forum/bd-p/PTCEducation area.
Option 2: Publish pictures of Creo window with appropriate notes. This enables me to recreate your test data.
