Assembly Relationships - Same Part File
  • January 15, 2010
  • 7 replies
  • 3337 views
Hey, I'm assembling some modular furniture and for example want to use the same part file for two doors, but I want them to be two different heights. Is there a way to change the dynamic dimension (d0:8) so that they each have their own one (i.e they're independent)? At the moment I'm just duplicating the part file so that I can have a different verison but that's not really ideal as fundamentally they are the same thing. Kind Regards, Scott
Scott, Use the Flexibility functionality. Open the door part. Click Edit > Set Up > Flexibility and select the feature having the height then select the height dimension. This will allow you to assemble the door multiple times with your choice of the height value each time. Back to the assembly, you don't have to delete the doors and re-assemble them. Just redefine a door component and you'll see the flexibility in the placement dashboard. You can alter the height from there. See Help Center for more detailed info.
January 15, 2010
If both doors are identical in every other way and only vary in height I think a family table of the door work for you.
See the following from the Help files: file:///C:/proeWildfire%203.0/html/usascii/proe/fundamentals/fund_five_sub/about_configuration_files.htm You can also find this by going to through the Help menu to Pro/ENGINEER Fundamentals--Pro/ENGINEER Menus--The Tools Menu--Using Configuration Files
