Assign materials once
  • February 1, 2019
  • 4 replies
  • 2802 views
Hi All,
In Creo we can assign the material to a part easily. My question is how can we utilise this information downstream? Hoiw do I use that designated material in the drawing and in the windchill attributes. Currently I seem to have to assign/ define in multiple places. This is open to error from duplication of effort and creates confusion if there is a mismatch. I surely can't be the only one who has experienced this issue.
Regards
Best answer by BenLoosli
In our start part, we have:
/*** SET MATERIAL PROPERTIES ***
IF PTC_MATERIAL_NAME=="UNASSIGNED"
MATERIAL="UNASSIGNED"
MATERIAL_DESC1="NO MATERIAL ASSIGNED"
MATERIAL_DESC2=""
MATERIAL_DESC3=""
ELSE
MATERIAL=material_param("PDM_NAME")
MATERIAL_DESC1=material_param("DESCRIPTION1_U")
MATERIAL_DESC2=material_param("DESCRIPTION2_U")
MATERIAL_DESC3=material_param("DESCRIPTION3_U")
ENDIF
In our material files, we have:
Name = DESCRIPTION1_U
Type = String
Default = 'UNS S30403, STAINLESS STEEL'
Access = Full
Name = DESCRIPTION2_U
Type = String
Default = '304L STAINLESS STEEL'
Access = Full
Name = DESCRIPTION3_U
Type = String
Default = '304L SST'
Access = Full
You can add any information to your material files that you need and then pull it to a parameter for your part descriptions.
What sort of downstream information are you trying to get?
Give us an example of what it is you want?
We pull parameters from the material files and use them to populate our part description material information.
RoyCrerar1-VisitorAuthor
Hi, At the moment when I assign material to the CAD part I cannot see how I can reuse that data in the Drawing for example. We end up using a manually entered attribute to reflect what was already specified in the Part.
I really would like this to pull through into the WTPart as our typical BOM shows the material, supplier and pigment. We have a number of components that are medical and we want o ensure the correct grades and pigments are used.
BenLoosli23-Emerald IIIAnswer
MATERIAL_DESC2=""
MATERIAL_DESC3=""
ELSE
ENDIF
Type = String
Access = Full
Type = String
Access = Full
Type = String
Access = Full
