assigning a variable
  • February 5, 2014
  • 4 replies
  • 3297 views
In a previous version of ProEngineer I was able to assign a value to a varible then use it to build a parametric model. An example I could give D the value of 4.00 and then set a dimension in my model d1=D, then I could build relations from there. I could go back and change the value of D, regen the model and everything would change accordingly. The problem I am having with creo parametric 2.0 is I can't find where to set the value of D.
Best answer by neomechanikos
Tools --> parameters. Hit the green plus button. Type in the name, select variable type, and add the value.
Creating a variable and assigning a value can also be done in a relation. Tools --> Relations
D=4.00
The benefit to doing in a relation is you can add a comment to explain what is going on along with the relation you create to control your dimension. i.e.:
/* Sets the diameter of widget to parameter D
D=4.00
d1=D
D=4.00
D=4.00
d1=D
bcooper1-VisitorAuthor
Thanks, that wil work.
