Automatic bend notes not appearing on drawing
  • April 18, 2013
  • 0 replies
  • 517 views
Hi All
On Wildfire 4 m220 I have noticed at times that sheetmetal parts which contain 'two-sided' cuts (i.e. removing material from both green and white side at the same time) will not show the automatic bend notes on the drawing for any folds that exist. In this example the cuts are intersecting the folded geometry.
If you produce the same geometry using the old technique of creating a white sided cut followed by a green sided cut the fold notes will show.
