7-Bedrock
April 24, 2014
Axis Display and Csys display on Creo 2.0 M100 is grayed out !
  • April 24, 2014
  • 8 replies
  • 7630 views
We have just upgraded to Creo 2.0 M100 and the 2 display options "Axis Display" and Csys Display are grayed out , why? how to correct?
Best answer by Mahesh_Sharma
Robert,
This is because of change in functionality from M100 datecode. If display of planes or axis is set to no in config.sup, options will inactive in interface. Remove/Comment config options display_coord_sys and display_axes from config.sup to enable in interface.
Mahesh_Sharma
22-Sapphire I
April 24, 2014
Robert,
Mahesh,
These display options have always been a preference setting for an organization and a users preferred start environment. They should not have been changed without some way to control this overall action with another config option.
David
It almost makes sense to change it, if the change is as described. The point of config.sup is to make changes that users cannot override. If there was some reason to never allow access to csys and axis display, then turning it off in the config.sup should do it.
It's been the case that adding a mapkey to config.sup prevents all other mapkeys from being used, even other mapkeys in the config.sup.
Simple rule? Don't put things in the config.sup if you expect users to be able to change the status of the options.
I am in China, Please modify the system color, that is the path: file/options/system colors/datum
