Axis Display in Drawing-conclusion
Sorry Folks but I discovered something further on this Axis issue and
don't want to mislead anyone with my incorrect previous message;
It seems Regenerating the drawing or Updating Draft was not the problem,
it was simply not being in the correct tab... you need to be in the
Review Tab to fully adjust both endpoints of an axis. This tab things
gets me all the time... it will take a while to get used to that.
Oddly, while in Annotate mode, I can still select the axis and drag
endpoints, but the results are no good. Wish they didn't even let me
select it if I wasn't in the right mode, like when I am in Layout mode
and I try to drag a dimension, it's a no-go...
Now I don't like the fact that I can drag a dimension around unless I am
in the correct mode, but at least I know that when I am unable to pick a
dimension it's because I need to switch modes.
thanks
Paul
Paul Mailloux
Cad/Cam Applications Engineer
NyproMold Inc
144 Pleasant Street
Clinton MA 01510
thanks
Paul
Paul Mailloux
NyproMold Inc
144 Pleasant Street
Clinton MA 01510
