Blank BOM Row
  • February 5, 2010
  • 2351 views
Anyone know of a good way to add a blank row in your BOM where you removed an item. Currently we use some dummy parts and then blank the information out with some relations but sometimes this is a real pain.
Why can't your dummy parts just have null (empty)values in the parameters? with our BOM, that's all it would take.
Our part number column uses the filename (without the extension), but even if i could use a blank parameter it would still leave the quantity.
