bolt joint analysis
- June 30, 2017
- 2 replies
- 1967 views
I am trying to run a simulation on a bolted joint and I have attached it. I keep getting errors and any help is appreciated. The bolts were represented as volumes because I am interested about the stress in the bolts due to pre-loading. Later on I want to analyze the bolts with a tightening torque load and embedding, but I am not sure how to due the embedding. I did not model the actual threads but the threaded part is connected with simple springs and weighted links. I think the model is failing due to something with the weighted links. I applied a pre-load by creating a volume feature in the bolt. I dont know if I should apply a thermal load on the bolt.
Any help would be greatly appreciated.
