BOM balloons that are indexed starting at 10 - 20 - 30?
  • June 22, 2016
  • 2 replies
  • 1217 views
My table reads 10 - 20 - 30 for item #'s. but my balloons are still 1 - 2 - 3.
Thanks.
18-Opal
June 22, 2016
Hi Steven,
Did you create a relation to show the repeat region index to be 10, 20, 30, etc.?  If so, then you will need to create a custom BOM balloon symbol and call out \rpt.rel.<parameter_name>\.
For example, I created a repeat region relation to show my report index as 001, 002, 003, etc.  In my relation, I defined parameter test.  In my custom symbol, I created a note and called out \rpt.rel.test\.  My BOM balloons now show 001, 002, 003, etc.
Amit
Mahesh_Sharma
22-Sapphire I
July 6, 2016
Steven,
Did you get the answer of your query in reply from Amit? If it answers, mark that as correct answer for post.
