BOM indexing by Feat#
  • October 10, 2017
  • 2 replies
  • 1922 views
is it possible to set BOM index by Feat# as I have it in Model tree?
I have large assembly and when I've assemble it I've inserted parts and subassemblies from front to back as they are installed phisically on assembly. Now I would like to have the same order of indexing in BOM table on drawing.
Than I will know for example that item with index 12 is installed in front of index 37 just by look on BOM table.
If there is also any other way to solve this, please share.
Thank you,
Simon
Hi Simon
Are you solved the problem?
I need the answer to your question.
Thank you,
Ali
For examples : https://www.youtube.com/watch?v=uT5N6jDlRQE
StephenW
Your BOM table probably has a sort order specified. By default, the BOM sorts in the order assembled.
To check go to the table tab, repeat region, sort region, select the bom, use Clear All to remove the current sort order and then Done.
