BOM: Part Position instead of Index
  • April 3, 2017
  • 1250 views
Dear community,
Is there a simple solution to list the part positon instead of the part index in a multilevel BOM?
I mean, with &rpt.index we got:
1 (level 1)
2 (level 1)
3 (level 2)
4 (level 2)
5 (level 1)
6 (level 1)
And in fact, I need :
1.0
2.0
3.0
3.1
4.0
5.0
So we can see that 3.0 and 3.1 belong to a sub-assembly.
Pascal
A have the same task and found a way. Need open relations in repeat region:
1) Add parameters to repeat region
RPT_INDEX
RPT_LEVEL
POZ = ""
POZ1 = 0
POZ2 = 0
POZ3 = 0
POZ4 = 0
POZ5 = 0
OLDINDEX = -1
LEVEL = 0
2) Add relations
/*--Reset counters if starts from first line in table
IF rpt_index == 1
 POZ1 = 0
 POZ2 = 0
 POZ3 = 0
 POZ4 = 0
 POZ5 = 0
 POZ = ""
 OLDINDEX = -1
ENDIF
LEVEL = rpt_level
IF OLDINDEX != rpt_index /*1
 IF LEVEL == 1
 POZ1 = POZ1 + 1
 POZ2 = 0
 POZ3 = 0
 POZ4 = 0
 POZ5 = 0
 OLDINDEX = rpt_index
 ENDIF
 IF LEVEL == 2
 POZ2 = POZ2 + 1
 POZ3 = 0
 POZ4 = 0
 POZ5 = 0
 ENDIF
 IF LEVEL == 3
 POZ3 = POZ3 + 1
 POZ4 = 0
 POZ5 = 0
 ENDIF
 IF LEVEL == 4
 POZ4 = POZ4 + 1
 POZ5 = 0
 ENDIF
 IF LEVEL == 5
 POZ5 = POZ5 + 1
 ENDIF
 POZ = itos(POZ1)
 IF POZ2 > 0
 POZ = POZ + "." + itos(POZ2)
 ENDIF
 IF POZ3 > 0
 POZ = POZ + "." + itos(POZ3)
 ENDIF
 IF POZ4 > 0
 POZ = POZ + "." + itos(POZ4)
 ENDIF
 IF POZ5 > 0
 POZ = POZ + "." + itos(POZ5)
 ENDIF
ENDIF /* 1
 3) Insert in position column
&rpt.rel.POZ
