BOM table: can't open properties or enter text for certain cells
  • January 10, 2012
  • 3 replies
  • 2952 views
Help! I have a BOM table (one I created) which works fine except for the fact that the column I reserved for entering descriptive text, notes, etc. will only allow me to do that in the first row. I can't even open the properties window for cells in that column in any row but the first. Any suggestions? Thanks, David
Best answer by DavidSurridge
This issue was resolved late yesterday afternoon. I realized that the column of cells in question might need to be outside the repeat region. This corrected the issue.
David Surridge
Hi
Can you give me a screenshot of your table after the following steps
1.select table
2.repeat region
3.switch syms
Regards
K.Mahanta
DavidSurridge1-VisitorAuthorAnswer
David Surridge
Hi
I was also expecting the same
thats why I asked to perform the above steps
It shows the repeat region area
Regards
K.Mahanta
