CABLING - Marker and tape feature
  • February 11, 2015
  • 1283 views
What is the use of Marker feature in cabling?
Can the tape feature be used to coil two cables together??
2-Explorer
February 19, 2015
As for this question:
You cannot use marker or tape features to fix coils of a cable/wire together, so that they clutch to each other. You will have to generate the coils' shape as desired by routing.
So I guess this leaves the question to whether you can create a tape or marker around more than one portion of the same cable at a time.
Anyone tried this?
P.S.
I have deleted thread https://www.ptcusercommunity.com/thread/59660 as it is clearly a duplicate of this thread and no one has answered it, too.
