CAD Data Translation- CATIA V4 to Pro Engineer
  • March 15, 2013
  • 10 replies
  • 3603 views
Dear All,
May I know do we have any direct database converter tool between CATIA V4 and Pro Engineer available in the market, by keeping all the model tree features in editable form and should able to create parametric drawings.
Best Regards,
Hari
"Sharing knowledge is the way to immortality"- His Holiness the Dalai Lama.
Hi, you can use PTC Creo Interface for CATIA V4 (if you made changes in Catia you can apply this changes to your model in Creo): more information you can find here: Creo Elements/Pro Interface for CATIA II with ATB Overview
Vladimir
Thank you very much Mr. Vladimir!
May I know can use the same model tree of Catia file( all the features) and that features we can be edit in pro/e.
Hari
Dear Hari,
If you need to manage design in Creo (change/edit/remove shape in Creo) you can use PTC Creo Flexible Modeling Extension
It is much cheaper solution like PTC Creo Interface for CATIA V4
Vladimir
Dear Hari,
It is better to try CAD translation softwares for conversion of file. To open Catia V4 in V5 you can use CatiaV4 to V5 Migration option which requires adittional liscense.
Thank you.
Prakash R
