Dec 16, 2017 4:01 PM UTC
CAD software for metal stamping company
I need some help from all of you.
I'm, with some friends, creating a new company, where we will develop metal stamping tooling (progressive and transfer dies). We are evaluating the needed softwares, and the most proper ones from our job.
Today in the company that we all still work, we use NX and CATIA (I'm a CATIA user). But as far as we have noticed, CATIA and NX are truly expensive softwares, and we need to ponder what to use for our new company.
What we are evaluating.
For simulation we had chosen autoform (that's closed)
For cad we have several possible solutions.
CATIA -> Not much probable, due to price
NX -> Not much probable, due to price
Creo -> interesting choice, but there is some lacks. To create metal stamping layouts, determine the pre cuts, make some quick analysis to metal stamped parts, there is not enough good tools. But for modeling and general surfacing, looks really powerful. Price looks reasonable.
Cimatron -> Very nice to determine the pre cuts, make some quick analysis to metal stamped parts. For 3d modeling there is plenty of libraries for metal stamping tools, But we don't know much about their capabilities to Draw. Price we still don't know.
ZW3D ->Very nice to determine the pre cuts, make some quick analysis to metal stamped parts. Interesting modeling options. Very low market share. Really interesting price
VISI ->Very good to determine the pre cuts, make some quick analysis to metal stamped parts. Interesting morphing capabilities to prevent spring back. Looks good also in surfacing and in general preparation of parts surfaces. It doesn't work with individual parts, it's parametric philosophy it's to limited. Price we still don't know.
SolidWorks -> we have tested it and there is a few things that we have disliked it, so it's not in the equation.
SolidEdge -> we have tested it and there is a few things that we have disliked it, so it's not in the equation.
Autodesk Inventor -> we have tested it and there is a few things that we have disliked it, so it's not in the equation.
Looking to our resarch, there is not a software that can provides a powerful choice for every area that we will need. So we are open to have 2 softwares for diferent needs.
For example:
Visi + Cre
Visi + Cimatron.
What do you know about these softwares, and their capabilities for this type of work?
Do you know any other softwares that can fulfill our needs?
Dec 18, 2017 3:46 PM UTC
If your new company is only developing the stamping tooling, do you have prospective customers to supply the parts and do you have a company contracted to use your tooling to stamp the parts? Are you manufacturing the tooling you design or subcontracting the machine work?
One thing to consider is the CAD package of your customers. How much translation do you want to be doing to bring in their models to your system. If you are not on their system of choice, will they provide STEP models for you to import. NX and Creo have builtin translators, for an extra charge, so you can read native files from other CAD systems.
CAD_user14-AlexandriteAuthor
Dec 19, 2017 7:54 AM UTC
For now, we will only concentrate to develop the design of the tools. Later we will analyse to expand our business and mill, assemble and make the try outs. ou tools.
From what we have been discussing with our potential costumers, we can provide them a STP file.
Yes Creo, NX, Cimatron (Not for all of file types), ZW3D, are able to open files from other softwares.
Dec 20, 2017 1:29 PM UTC
For what it's worth, I'm a draftsman for one of the (if not "the") largest tool and die companies in the world. Creo is our primary CAD software, but we also use AutoCAD for legacy files.
Jan 23, 2019 11:38 AM UTC
Visi+ Cre
VISI Modelling is the foundation of all VISI products and provides a robust and powerful solid and surface modelling system based around the industry standard Parasolid® kernel. Combined with Hexagon’s surface technology, model analysis and 2D design, VISI Modelling offers complete flexibility to construct, edit or repair the most complex 3D data. Features at a glance: • Easy to learn intuitive interface • Extensive CAD interfaces • Industry standard Parasolid® kernel • Combined wireframe, solid & surface modelling • Solid & surface boolean operations • Surface repair & analysis • Edge tolerance manipulation • Powerful blending • Intelligent model deformation • Fast rendering & texture mapping • Mechanical curve construction • Associative tool detailing • Automatic B.O.M. creation Extensive range of CAD interfaces. VISI can work directly with Parasolid, IGES, CATIA, Creo, UG-NX, STEP, Solid Works, Solid Edge, Inventor, ACIS, DXF, DWG, JT Open, STL and VDA files. The extensive range of translators ensures that users can work with data from almost any supplier. The ability to skip corrupt records during the import process provides a platform from where the most inconsistent data can be managed. Very large files can be handled with ease and companies working with complex designs will benefit from the ease with which their customer’s CAD data can be manipulated. True hybrid modelling. VISI provides a dynamic structure from where it is possible to work with either solid, surface, wireframe or a combination of all three without any restrictions. Solid modelling has become a fundamental cornerstone of design but is often limited to prismatic or basic geometry. Solid modelling commands include boolean technology such as unite, subtract, extrude, revolve, sweep, cavity, intersect and hollow. Surfacing technology however provides a different set to tools and techniques for more organic, free-form geometry creation. Surface modelling functions include ruled, lofted, drive, sweep, n-sided patch, drape, tangent, draft, revolved and piped surfaces. These modelling commands combined with advanced surface editing make it easy to heal imported geometry or construct the most complex 3D data. Advanced Modelling - Deformation. Advanced Modelling provides technology that will benefit all users in every industry sector. The Advanced Modelling tools are capable of deforming geometry while maintaining model integrity and holding curvature up to G4 constraints - This is particularly important for parts of high gloss (black, white, chrome) or that have aerodynamic requirements. Model editing includes bending, twisting, stretching and deformation, which allows the CAD operator to define the start and end geometrical conditions to drive any model change. Practical applications include springback for sheetmetal, product design changes and geometry healing. Kinematic Simulation. The kinematic options include constraints to simulate the physical movements of gears, gear racks and rails. The motion study simulation tools allow the user to define timelines which control the start & end movement cycles for various groups of components. The physical interaction of model geometry can be detected and the results of complex mechanisms validated - ideal when checking for potential collisions with slides, cams and lifters. Surface repair and editing. Small gaps between surfaces on imported models can be automatically healed preventing the time consuming process of rebuilding very small surface patches. Where surfaces are corrupt or missing VISI will automatically create the edge curve geometry making it easy to rebuild new faces using the comprehensive surfacing suite. To ensure the new surfaces are within tolerance, the new and the old surfaces can be compared to check for min/max distance and curvature deviation. Closing a surface model to produce a solid body eliminates construction problems later in the design process and immediately brings the benefits of solid modelling to the user. The ability to seamlessly switch between solid and surface technology provides unlimited freedom, ensuring the user can work with difficult CAD data. Powerful blending. Constant radius, variable radius, disc, hyperbolic and elliptical blends can be constructed directly onto a solid model. Blends can be propagated along tangent edges to quickly sweep across a component. For very complex blending conditions or when working with inconsistent data, blend faces can be constructed as surfaces in an untrimmed state providing greater flexibility. Trimming is easy using either wireframe curves, edge geometry or existing faces. Full range of 3D curves and split line curves. Create a theoretical split line curve or construct 3D curves including iso-parametric, cross section, helix, ellipse, spiral, hyperbolic and other mechanical curves. Advanced curve editing provides the ability to force tangency / periodicity, move control points, join or extend curves. Combined curve reprocessing allows multiple command combinations to greatly simplify the process of creating high quality curve geometry for surface construction, trimming or machining. Ease of use. Simple menu and icon commands with context sensitive on line help make it quick and easy to start using VISI. Dynamic rotation, zoom and pan, together with programmable function keys and mouse buttons help speed up the operation of the software. Unlimited undo and redo operations with user definable bookmarks enable the designer to move backwards and forwards throughout the design process. Multi layer and multi origin control with user definable color pallets and line styles makes it easy to review, create and work with very complex designs. All information is stored in a single file providing easy access and reducing the burden of data management. Managing one session of the software with all the components available for editing at the same time provides much greater flexibility. Super fast rendering, texture mapping and dynamic sectioning make it easy to visualize CAD files and large assemblies. Automatic creation of 2D views. A complete set of 2D detailed drawings can be generated directly from the 3D model. This includes fully editable 2D and isometric sections views, automatic dimensioning and hole type and position tables. Individual details can be created from any component in the assembly and displayed as a mixture of 3D rendered and 2D drawings. Any standard catalogue component will have the correct detail representation within a section view. A change in the 3D model will result in a modification to the 2D view along with any fully associative dimensions. Parts list table items and their respective balloon references can be added to the drawing using dedicated assembly management tools. Manufacturing modules. All the VISI applications run in one easy to use environment with knowledge based modules available for mold tool and progressive die design. Once the tool design is complete, machining of plates can be completed using feature recognition; drilled hole features and apertures are automatically selected with the correct drilling cycles and 2D milling routines applied. For 3D forms, mold cavities or forming stages on a progressive die, VISI Machining will create the toolpaths directly on the model incorporating conventional, high speed and 5 axis toolpaths. Keeping the model within the same product environment throughout the entire project, from design to manufacture will guarantee data consistency and greatly smooth the design process. Due to the integrated nature of VISI, manufacturing of individual plates can be completed using feature recognition. Drilled hole features and apertures are automatically selected with the correct drilling cycles and 2D milling routines applied. For more complex forms VISI Machining can be used to generate both conventional and HSM cutting toolpaths. Complex punch apertures and the corresponding solid punches are easily manufactured with seamless integration to Wire EDM.
