Calculation Volume of a Vial
- December 6, 2017
- 5 replies
- 8152 views
Hi, was wondering if someone had any advice on the attached drawing I've been given to calculate the volume.
The question we've been given is:
- b) Calculate volume of the liquid in mL for initial vial design. Use suitable dimensional parameters and Creo relations to calculate volume. Describe the scenario to calculate volume.
Calculating volume is fine and I know how to put the formula in for this but would you calculate the body first (10 diameter x 36.83 then the neck 5 diameter x 6.25 height and add together?)
And would you agree the outside thickness is 1.25?
Any advice would be appreciated as our lecturer takes days to get back with a response!
