18-Opal
May 15, 2018
can a CREO create xls files?
  • May 15, 2018
  • 1497 views
Hi all
CREO can makes excel file but file extension is csv
Our customer requirement is create xls file from BOM
is it possible?
we had checked and post about tooltip at Customization
but we didn't get requirement function still now
thanks
CHASEONHO18-OpalAuthor
18-Opal
May 15, 2018
When i save the model tree, if i declare the extension as xls, it will be saved as Excel.
However, this does not divide the cell.
As you can see, the tree structure is in one cell.
If possible, it is good to insert data into each cell when the tree is saved as xls.
I also want to be able to control where the tree will be stored as xls (the base structure appears to be inserted sequentially from A1).
