can a fixed length be designated to a spool
  • July 16, 2013
  • 4 replies
  • 1600 views
hello,
In the spool you can set a variety of electrical parameters. Be can you set a spool or wire which has a fixed length.
greetings, Koen
Best answer by BrianMartin
Hi Koenraad...
Rama is totally correct... you can't fix the length of a spool. You can only fix the length of portions of specific wires/cables.
I'm really sorry I haven't been around. But if there are any other questions, please ask and I'll try to keep this email thread tagged so I can respond.
Thanks!
-Brian
Dale_Rosema
Koenraad,
Maybe Brian will be able to chime in, but I thought I'd link to his presentation and see if you can find the answer to both of your questions there:
http://communities.ptc.com/community/creo/piping-cabling-schematics/blog/2013/07/11/failing-with-style-ninja-cabling-2-draft-presentation
At the end he has a power point you can down load, too!
Thanks, Dale
Hi Keon,
We can fix the length of the wire/bundle (not spool) in 3D harness assembly, but cannot control the length through parameters.
Regards
Ramakrishna
Hi Koenraad...
Thanks!
-Brian
kachten1-VisitorAuthor
Thanks everyone for your input!!!
Greetings, Koen
