Can Creo 1 import excel x-y or point data to form a curve?
  • October 30, 2012
  • 7 replies
  • 10045 views
Hello all,
Let's say I have a bunch of X - Y data that forms a complex curve in Excel. Just 2 colums of data.
Now let's say, I want to bring that data into Creo 1 (M40), how would I do that?
Do I need to convert it to a CSV file?
Do I need to convert it to a 2D cad file first?
Do I need to use a special file with special syntax?
I need to take this data, probably as points and then form a datum curve to form a surface.
What do you think the easiest way to do this is? Keep in mind the original data is in Excel spreadsheet format.
Thanks in advance!
Peter
Best answer by Peter1
I have found an answer myself....
Search in the help section "To Read in Spline Coordinates from a File" or look for .pts file.
It works great. Thanks me.
Peter
Dale_Rosema
From what I gather by this product suggestion, there is not a point table:
http://communities.ptc.com/ideas/1446
Dale
Peter11-VisitorAuthorAnswer
Peter
There is also a way to do this with exporting curves to IGES and re-importing them as points. Very archaic.
But yes, in your case, formatting the data into a points file is relatively straight forward.
Why would I export the data and then re-import it back in if I already have the geometry in Creo? The original question was how to import non-CAD points into Creo.
Patriot_1776
Hey, no fair asking a question, and then answering it just to get the 3 points!
Trust me, I wish I had found this out 6 months ago...
