Can I retrieve unsaved objects that are in session?
Hello
I accidentally closed the windows for a skeleton assembly and a part. They are still in session but they are unsaved. Can I reopen the windows and save the objects?
Edit: I'm using Creo Parametric Academic edition.
anordbergAnswer
This must be a reoccurring question. I found the following answer.http://communities.ptc.com/thread/39431
"Just click the "in session" button in the file open dialog and click on the "file name" you are trying to re-open.
By default, if a part or assembly is in session, it will read this before Creo/WF/Pro/E will read the disk."
anordberg1-VisitorAuthorAnswer
hey axel
but do remember not to "erase objects not displayed"
