Can't copy parameters in tables sometimes
  • December 6, 2013
  • 2 replies
  • 858 views
I've made drawings with several tables that show parameters and have to
duplicate them.
For example, I'm making a simple table of 3 cells:
- &model_name
- &dwg_name
- &pro_mp_mass
So I have the values of the 3 parameters in my table.
If I copy and paste this table, the new table is containing this
- model_name:1
- &dwg_name
- pro_mp_mass:1
So, for first and third lines ''&'' symbol disappear and '':1'' is added.
Then, only the second line continue to display parameter value.
I get this even if I copy and paste the table in the same drawing.
Anybody knows what happened and how to do for continuing having parameters
values?
What version and build are you using?
Have you tried to save the table and then import it instead of copy/paste?
Is this a multi model or assembly drawing? The :1 is the session ID for the part that the parameter comes from. The middle parameter calls from the drawing, so no session ID required. I don't think the session IDs are added if there's only one model in the drawing.
