Can't print BOM from embedded browser in Creo3
  • January 10, 2017
  • 10 replies
  • 3766 views
I am unable to print from the browser within Creo 3.
Is this a problem unique to me or does everyone else have the same problem?
Dan
Best answer by StephenW
Things you might try:
set the config option WINDOW_BROWSER_TYPE CHROMIUM_BROWSER
it looks the same, acts the same but for me it solved some odd issue with windchill blank screens  in the embedded browser
I think you have to restart creo to get that change to actually take effect.
Not sure why it doesn't create a bom file for you. That's been standard since, well, forever. File is placed in the working directory and is assyfilename.BOM.1 where assyfilename is your assembly file name and bom is the file name extension. (edited)
dross1-VisitorAuthor
36 VIEWS and no one can answer whether they have this problem or not?
Hey, PTC, what do you have to say about this?
StephenW
I'm assuming you are using Tools - Bill of Materials.
I just right click in the browser and click print and it works.
I have set the browser type in the config to Chrome based browser.
Also, when you create the bom, Creo creates a text file in the working directory with the same info in a text format. It would be much easier to import to excel or whatever.
I tried right-clicking and selecting print, nothing happens.
I am not using Chrome, however, I am using whatever the default is, I think Internet Explorer.
It does not create a text file. Perhaps that is a config option.
If I choose to save it, it saves in html format.
Windows 7 the browser would be IE.
Windows 10 the browser would be Edge.
On my home machine printing from Edge does not always work so I have to use IE to print some pages.
Not sure what PTC support is for Edge off the top of my head.
Creo will not use Edge inside Creo as the embedded browser.  Even on Windows 10, Internet Explorer 11 is still installed.  Depending on the windows_browser_type config option Creo will either use Internet Explorer 11 (from the PC) or Chrome (bundled with Creo).
