Can't remove an image from a model
  • November 21, 2017
  • 8 replies
  • 5934 views
I added a few images to my model using View > Model Display > Images > Add
Now I want to remove those images. I tried following PTC's instructions (link below), but I'm stuck at step 2; I can't select an image. Clicking the image in the graphics window does nothing, and when I click the imported images dropdown, it's empty.
Is there any way to get rid of the images from the model? I've tried moving / deleting the source image, but this just shows a gray area where the image used to be and gives a "could not locate image" error.
https://support.ptc.com/help/creo/creo_lcd/usascii/index.html#page/lcd/layout/fund_four_sub/To_Remove_a_Trace_Sketch.html
I'm using Parametric 2.0.
Best answer by MartinHanak
I opened my test assembly and included an image in its sub-assembly. Now I can reproduce your problem, when I activate main assembly. When I activate sub-assembly, I can remove the image.
I guess that you do not know, in which assembly component are your images included. Unfortunately I do not know how to find parent model of the image easily. You have to search all assembly components one by one manually.
BHOoi
Not sure you can see the menu below:Capture.JPG
you can then select the image either directly from graphic window or pick it from "Imported Images"  and hit "- Remove".
tbow1-VisitorAuthor
  • activate View tab
  • expand Model Display group
  • click Images button
  • Images tab appears
  • select picture
  • click Remove button
  • click OK button to finish image operations
tbow1-VisitorAuthor
@MartinHanak wrote:
  • activate View tab
  • select picture
I'm stuck at step 5 in your list; I can't select an image. Clicking the image in the graphics window does nothing, and when I click the imported images dropdown, it's empty.
please attach screenshot to show what is displayed on your monitor.
