Can we add or delete a dimension in creo drafting using pro/program?
  • July 8, 2016
  • 2 replies
  • 1204 views
i am trying to automate the extrude feature by suppressing or unsuppressing. i want that to reflect in the drawing as well.
if i understood the question right you should use Drawing program
2-Explorer
July 6, 2017
Although this is an old question -
Pro/Program changes model and assembly logic only. It does not affect drawings. You can use Toolkit if this function is required.
