Can you use a assembly parameter(or relation) in multiple parts?
I am trying to figure out how to set a parameter in the main assembly and have it adjust multiple part models.
In other words, I have a part number for an assembly and I am using Extrude > Text to put the number on a bunch of parts.
I thought this would be simple but I tried a bunch of parameter/relation things and searched the forum and help files a bit, and I do not see a simple answer.
Even if you have to do some kind of link in each part model, that's fine. Once I set it up, I am going to make full copies of everything a bunch of times and then start modifying things.
thanks
