Cannot Edit Tolerances in Creo Drawing – Tolerance Tab Greyed Out
Hello, I’m having an issue in Creo Drawing:
  • When I select a dimension and go to the Tolerance tab, all options (General, Shaft, Hole) are greyed out/uneditable.
  • I have already enabled tolerances in the model properties.
  • I have already retrieved ISO tolerance tables.
  • The dimension is not a reference or driven dimension.
  • Curiously, some drawings work fine, and their Tolerance tab is fully editable.
Has anyone encountered this? How can I enable the Tolerance tab to edit tolerances in drawing dimensions?
Thank you!
luiz.hnmAnswer
The issue was also related to drawing configurations. At first, I set the tolerancing standard in the 3D model (Model Properties → Tolerancing Standard). However, I believe that when using GD&T, the detailing follows a property from the drawing file rather than the 3D model. So now I also go to Drawing Properties → Tolerancing Standard and apply the standard there. After that, I’m able to use the Tolerancing tab.
tbraxton
In drawings where you have this issue what is the drawing detail option tol_display set to? The default is no, change it to yes and see if that resolves the issue.
luiz.hnm12-AmethystAuthor
Thank you for the reply! Unfortunately, it didn’t work.
tbraxton
It is hard to determine root cause without access to a data set with the issue. Are you able to post an example of a model and drawing exhibiting the problem? There are many things that can contribute to this symptom.
luiz.hnm12-AmethystAuthorAnswer
