11-Garnet
February 27, 2013
Cannot get in pro program
  • February 27, 2013
  • 3 replies
  • 1554 views
Has anyone had this problem? When trying to Edit Design in program I get a screen that just flashes and disappears. Maybe I thought it hid behind Creo. It did not.
I'm running Creo 2.0 on Windchill 10.1 M020.
I'm dealing with some model that I believe came from the outside. I need to remove some inputs that do not apply any longer.
Thanks in advance
santinou11-GarnetAuthor
11-Garnet
February 27, 2013
Never mind. Had to set my config.pro option 'pro_editor_program' to a valid editor.
Thanks the same.
Hallo Santo Uccello,
would it be possible to tell me how you fixed your Problem. I have the same problem like you in Creo Parametric 3.0, but when I open my config. pro option ther ist no "pro_editor_program".
(in Creo Parametric 2.0 does the edit Modus work even without such a "pro_editor_Program")
Thanks a lot for your help
Karl Hilbig
Karl,
I hope the correct option name is PRO_EDITOR_COMMAND
Martin Hanak
