Cannot Hide Quilt Edges
Community,
I have imported a complex model that is made up entirely of quilts, and of course, quilts have edges.  After importing the model into Creo 6 and selecting the No Hidden icon, all the lines still show through like a wireframe display.  I cannot display the model online, but no matter what combination of system colors I try, they always show through, even with Black on White.  There is nothing in the layer tree to turn off, it's all quilts.  Has anyone encountered this before, and is there a solution?  Thanks in advance.
kdirth
kdirthAnswer
In the drawing view options, under View Display, there is Hidden line removal for quilts.  Select the Yes radial button.  This should treat a quilt as a solid and hide anything behind a quilt if Display style is set to No Hidden, and make all edges behind a quilt hidden if the Display style is set to Hidden.
Not sure there is anything you can do for the model view.
StephenW
Is this a drawing view? Or a model? Is there a x-section turned on?
Visibility get funny with x-sections turned on sometimes, not all the time.
If its a drawing and you have a x-section in the view, edit the cross section, select the options tab and select the "include all quilts".
ThoRig14-AlexandriteAuthor
Thanks for responding.  It's actually both.  But let's start with the model view, because the drawing view is related to the model.  You know the display style types, such as, shaded, shaded with edges, hidden, no hidden wireframe, etc.
When I select HIDDEN, that's suppose to hide the lines that are behind the surfaces.  Instead, when I select HIDDEN, it's just like WIREFRAME, and all edges can be seen.  The models is an imported STEP file composed of all quilts.
Never seen anything like it before.  I tried system settings Black-on-White, that didn't fix it.  I didn't know if this was the best board to place the topic.
StephenW
If you shade it, it looks correct? I have seen some problems with "sides" of surfaces being see thru. It's been years tho.
kdirth
kdirth21-Topaz IAnswer
Thanks kdirth.  That fixed it in the drawing, which is ultimately what I was trying to do.  That is an amazing tip.  For the solid model environment, I still cannot get it right.  Even setting the config option display to "hiddeninvis" did not fix it, and I thought that would do it.
I will take the solid model "problem" to tech support and see if they can determine the cause.  Thanks again.
Edit the definition of the import feature and go into Import Data Doctor (IDD).  See if there are wire-frame edges embedded inside.
Okay...I will try that.  Thanks.
