Cannot modify attachement of balloon with Pro/Cable
  • May 8, 2012
  • 0 replies
  • 439 views
Once I show a balloon in a Pro/E drawing that has a cable assembly I cannot modify the attachement of the balloon to the surface portion of the cable (Pro/Cables are different than Pro/Piping in that they are not solid geometry but surfaces.
Balloons can be attached to the entity ot to surfaces, but with a cable I cannot select the surface nor the edge of the cable to set the tip of the arrow from the balloon.
I could create a datum point at the location of the cable where I want to point to, but it is not a clean approach.
Any tips are welcome,
Ronnie Shand
