Cannot modify dimension tolerances thru ribbon when selected - sporadic issue
  • April 9, 2019
  • 4 replies
  • 2659 views
Dimension is selected yet specific (tolerances) areas in the ribbon remain randomly grayed out. Potential causes?
StephenW
It's possible the model is locked or otherwise not modifiable.
I am seeing a typical behavior that seemingly prevents this from being the case. If you add a dim to a model (ad###), show it in a drawing, then select it with the part unlocked - you get the dimension tab on the ribbon. If the part is locked - only the format tab shows up. I have run into the issue I mentioned, but I've never actually been able to replicate it. Closing and reopening, changing the format, these 'restarts' seem to reset whatever is causing it.
StephenW
Those are difficult to solve. When I start having glitches, I simply restart Creo and see if that solves them. If so, I usually don't worry too much about it.  If you can come up with a sequence that creates the issue, maybe we can help. Or maybe someone else has a suggestion.
