Centerline Style - Creo Drawing
  • May 30, 2017
  • 6 replies
  • 7866 views
How do I control the Hole Centerline style in a Creo 2.0 drawing?
The extents of the Centerlines project at least 5 times further than the diameter of the hole!
Message was edited by: Dan ONeill Added image...
doneill-21-VisitorAuthor
It should be in the same place where you would control the default offset of your dimension witness lines... which I can't find either..
2-Explorer
May 31, 2017
Hello Dan ONeill
let´s try to add in your *.DTL file following configs:
A) axis_line_offset --- default value 0,1
B) circle_axis_offset --- default value 0,1
One of this configs should help.
See attached list of *.DTL file configs. Description is in czech language, but configs itself are english and sometimes it can help.
Regards
Milan Bonka
Thank you for your help!
I ended up going thru:
     FILE... Prepare... Drawing Properties... Detail Options...
I found the properties you pointed out... but it took a lot of trial & error to finally come up with what I wanted.
I settled on:
     axis_interior_clipping     no
     axis_line_offset             -1.0
     circle_axis_offset           0.5
One other thing... It looks like once you drag the end of the axis there is no way to get it to reset back to the default.
You just have to drag it back...
Thanks again for the help.
2-Explorer
June 1, 2017
The same situation here.
It´s about testing...
Can´t give you better advice...
