Central Catalog Concern - Dependency item is missing from the Central Catalog
I opened up one of my diagram designs today and as I always do as my first step I chose "Tools -> Verify Catalog..." The central catalog is scanned and the "Catalog Verify Results and Resolution" dialog box opens. I had recently updated the central catalog so the "Out of date with central catalog" error has 1 item listed, which is typical. I click the box to show the list and then choose "update" as the resolution. For some reason I got an error "connectors,Dependency item (354288161-28) is missing from the Central Catalog". With this error the process stops and the diaram is not updated with the latest information from the central catalog. (connectors is the name of the datatable that I had recently updated)
My resolution was to choose "submit" as the resolution and update the central catalog with the submitted data. This appears to have solved my issue. I say appears because I'm not sure what I did or why this worked.
Has anyone had a similar experience? What might I have broken that i'm not yet aware of?
Nathan Gugliotti
