kdirth
kdirthAnswer
Creo does not create that specific dimension type.  You can create a note similar to it by placing the dimensions, setting the tolerance, and adding the dimensions to a leader note.  Once in the note, you will need to go to the model to modify tolerances.
StephenW
Using Angle x D chamfer, you can add a tolerance to the angle.
Can this tolerance be edited on the drawing (where all the other tolerances are usually edited)? Or are chamfer tolerances "trapped" in the .PRT file and can only be edited there?
StephenW
As with all shown dimensions, you can edit the dimension value or tolerance value in the model or drawing using the ribbon or by double clicking the value.
