Change active sheet with VBA API
  • April 5, 2018
  • 0 replies
  • 1019 views
 Hello.
I would like to change the active sheet on a drawing using VBA-API, but I can't find any way to do it, I'm new to VBA-API. The best I cold manage was to use macro to change sheets, which worked, but did produce somr undesired effect.
The documentation states "You can regenerate a sheet only if it is displayed.", so it must be possible to change  the displayed sheet.
My code so far
Public Sub change_sheet_parameter()
 Dim conn As IpfcAsyncConnection
 Dim cAC As CCpfcAsyncConnection
 Dim session As IpfcBaseSession
 Dim model1 As IpfcModel
 Dim sheetData As IpfcSheetData
 Dim sheetowner As IpfcSheetOwner
 Dim sheetInfo As IpfcSheetInfo
Set cAC = New CCpfcAsyncConnection
Set conn = cAC.Connect("", "", ".", 5)
Set session = conn.session
Dim oModelDescriptorCreate As New CCpfcModelDescriptor
Dim oModelDescriptor As IpfcModelDescriptor
name_w = "SHM-7457-004.drw" 'Name of the drawing
 Set oModelDescriptor = oModelDescriptorCreate.Create(EpfcMDL_DRAWING, name_w, Null)
 Set model1 = session.RetrieveModel(oModelDescriptor)
 Set sheetowner = model1
 Dim oWindow As pfcls.IpfcWindow
 Set oWindow = session.OpenFile(oModelDescriptor)
 oWindow.Activate
Set sheetInfo = sheetowner.GetSheetInfo(1)
test_ = sheetInfo.Height
MsgBox test_
'The part where I would like to change the displayed sheet.
sheetowner.RegenerateSheet (1)
End Sub
