change Creo 3.0 from offline to work on-line
I am using Creo Parametric 3.0 M190
Unable to to change Creo 3.0 from offline to work on-line, and setting up work spaces does not work.
Here are the errors that I faced
While I'm trying to get the program to work on-line, I get a Warning pop-up: You have no workspace to register, you cannot register this server without workspace.
1. A similar question - "Cannot Connect to Server From Creo. need workspace?": https://community.ptc.com/t5/Windchill/Cannot-Connect-to-Server-From-Creo-need-workspace/td-p/408804
2. Some articles about this problem:
I have found it easier to create a workspace from the external Windchill browser hen connect and register your Windchill server to Creo with the existing workspace.
