change datatable of a wire
  • December 2, 2015
  • 3 replies
  • 2334 views
I have a schematics to modifiy, on this schematics a lot of wire have a "bad" definition (mainly wire gauge is wrong).
I try to modify the dataset of the wire but i'm not autorized to modify if.
I search a way to avoid re wired all this wire...
Hi
Do want to select a different dataset aka to change the wire from 12g to 14g?
or do you want to change the contents of the dataset?
11-Garnet
December 3, 2015
Anthony,
Are you connected to a Central Catalog?
Dave
adupouy1-VisitorAuthor
yes i'm connected to a central cantalog, i have created my datatable, i want to move from the datatable to my personnal datable without make agin the wire...
11-Garnet
December 3, 2015
I hate to tell you, but unless you have privileges to modify the Central Catalog, you may have to create your own wire artifact tied to your new datatable, and then re-route the wires.
Let's try the easier route first: do you have permissions to the Central Catalog? Or is the admin of the Central Catalog willing to update the wire artifact with your new datatable?
Hi!
David is correct unfortunately, but if you make a fiber artifact with your own datatable attached to it, you may have the possibility to use the Change shape command, with this you can change the fiber shape to your own, and than apply a dataset (like this the wires should stay connected to the port, this one I cant confirm right now, but it's easy to try it with a simple xml export) it's not much but like this you don't have to reroute everything.
Best regards!
Laszlo
