Changing The Color Of A Hidden Line
  • October 15, 2013
  • 2 replies
  • 3384 views
Is there a way to change the color of a hidden line in a drawing? It would be much easier to see if it is red, blue, green, etc.
Best answer by ptc-1589706
Yes, you can change the hidden line color.
In Creo 2.0 while in the drawing go File->Options->System Colors->Graphics->Hidden Line. Make sure to select OK when finished.
Unfortunately I've found no way to make this change permanent through saving the configuration though it maybe related to the drawing property. I'm just to lazy to try and figure it out.
I hope this helps...
FTC_85211-VisitorAuthor
Thank you very much!! It is very helpful!!
