Clearance Hole Tolerance
I have setup my .hol file to include custom formatted notes for different hole configurations using the hole wizard which is very helpful. However, for clearance holes I would like it to callout the tolerance per ISO273. For example for a normal clearance hole for a M8 the hole size is 9mm-9.22mm therefore in the note I would like it to list the range rather than just the modeled value of 9mm. That way I can use the note as I have formatted it and not have to still go in and edit the tolerance. I see there is a column in the table called MED_DEC and CLEAR_DR_MED. What is the difference between these two columns? Is one the call out description and one the hole size to model? I couldn't seem to get it to work. I would like it to model a 9mm hole and have the note say 9.0-9.22.
